Old Honda ATC carb question
Old May 30, 2000 | 11:38 PM
ford400's Avatar
I have an 83 Honda 185 ATC. The carb is leaking out of the vent line. Also it seems to be cutting out a little. I was wondering what adjustments I could do to it to compensate for high elevation. See it came from Texas and is now in Laramie Wyoming at 7200 ft. There is a needle on the top that can be moved up and down should that be turned inward. Thanks for any help.
Old May 30, 2000 | 11:55 PM
JRM's Avatar
JRM
to fix your leak, pick up a new float valve at the dealer and remove the bottom float bowl while holding the carb upside down. after you take it off take a good look at how things look inside, then you will see the valve that you want to replace (looks like rubber tiped a acorn) just slide out the pin and move the float up and take the old valve out and slip the new one in and reinstall the pin. now gently bend the float upward or downward until it sits level with the carb when it is held upside down. To get it running better at 7,000+ ft I would replace the main get (the big hex headed one) with the next smaller size and raise that pin clip one notch that you spoke about.. should run smooth now
neilbedwell
Nov 10, 2018 11:02 AM
green giant
Jul 13, 2017 12:07 PM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
lovinhonda
Jan 25, 2000 09:17 PM
