400 at rancher 4x4 ? please help
Old Sep 5, 2003 | 09:35 PM
Quadmaster325's Avatar
Default 400 at rancher 4x4 ? please help
what i need to know is . does anyone else have a 04 rancher 400 at 4x4? if so have u had ur first maintenance yet? if so did thye adjust ur valves or inspect them .? because i had my first maintenance done and all they did is inspected the valves and now i can hear them ticing. just wanted o know if the valves were supposed to be adjusted the in the firts maintanance period? please answer need to konw thank u very much
patrick flynn
Old Sep 5, 2003 | 11:52 PM
TimTimTJ's Avatar
According to the manual, they should be inspected and adjusted if needed. I have not had my AT in for its first service yet, but the valve adjustment is supposed to be part of it.
-Tim
Old Sep 6, 2003 | 08:18 PM
mspiers71's Avatar
I have an '01 350 rancher ES, and seem to remember adusting them after 20 hours? can't remember the exact time frame. but it's very simple to do yourself. take off the valve cover, set piston to TDC on compression stroke, measure clearance with feeler guages, if necessary loosen adjusting nut, tighten adustment screw while holding nut to desired gap( I think it's 0.008) but it's definitely in your owner's manual, then while holding screw in place tighten that nut back up. piece of cake. once you take all the plastic off, and the tank, it's only about a 15 minute job setting the valves.
but your dealership will surely do your first service if you need it.
Old Sep 8, 2003 | 09:55 PM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
