TIRE SIZE VS. POWER
Old Sep 17, 2003 | 05:11 PM
BADASSBILLYREED's Avatar
Default TIRE SIZE VS. POWER
I Have a 95 300 4x4 and i was needing some new tires. I have looked at the itp589, outlaws, gator and the goodyear mudrunner. i was also concerned about a loss of power going to a bigger tire. My friend has a 300 with 25-10-12 (F) and 26-12-12(R), but has a tough time turning them over in the tough stuff. i want a bigger tire to hang with him and the rest of my buddys with 400s, 450s, and bigger. i need an aggressive tire and could use all the clearance that i can get. so if anyone has any thoughts i could definately use the advise.
Old Sep 17, 2003 | 05:29 PM
maxxismudder's Avatar
I recently mounted 26" gators on my rubicon. I could notice a decrease in bottom end power. I notice myself putting it in low more often than I ever did with the stock 25" tires on. I would not recomend going over 25" on a 300, you will really have a hard time turning them over in the thick stuff and also on hills.
Old Sep 17, 2003 | 05:48 PM
I was thinking about going to something like a 24-9-11 or a 24-10-11 on the front and a 25-10-11 or25-12-11 on the rear of i can find those sizes in a tread design that i like. Would that work or is that too wide on a 300?
Old Sep 18, 2003 | 09:37 AM
That should be fine, chcek with your friend and see if he has any problem with the tires rubbing on his. Thoes smaller sizes should save you some power. You will have to experiement with air pressure. I currently run 2lb in each of mine, smoother ride with less air and auctly steers better.
Reactant
Mar 30, 2022 02:08 AM
rcappie4
Jul 18, 2015 07:51 AM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
tweeder
Jul 5, 2015 01:57 PM
