Won't crank
Old Oct 7, 2003 | 11:03 PM
racerx5x5's Avatar
Default Won't crank
I have a 2002 400 EX, went riding last weekend riping around some trails with a little mud. I went to start it for the next round and it would not crank it just clicked. It did start later on it's own. It seen to be hit or miss the rest of the day,any thoughts on what the deal is? When it did clicking thing I tryed puting the lights on and thay did not dim.
Old Oct 8, 2003 | 02:01 AM
dirtroadrider's Avatar
Default Won't crank
Sounds like its time to buy a new battery. Put you battery on a charger overnight and see how it cranks the next morning. If it starts right off the bat. I say BATTERY $69.95 at your local shop.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 8, 2003 | 02:37 PM
Hondanutcase's Avatar
Default Won't crank
being an 02' your battery is no that old, but it still could be toast. I had the same problem you did, I checked the battery and the connections were loose. Check that first. If thats not it have the battery tested at your local auto parts dealer (they will test it for free). They also sell the same batteries as your Honda dealer for much cheaper.
Old Oct 8, 2003 | 04:14 PM
TheQuadSport230's Avatar
Default Won't crank
Yeah it's surely the battery, the same thing happened to my 300ex
Old Oct 8, 2003 | 06:57 PM
racerx5x5's Avatar
Default Won't crank
I will have to check it. I started it yesterday it fired right up.[img]i/expressions/face-icon-small-confused.gif[/img] I think I am going clean all the conections. Thanks guys[img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 8, 2003 | 07:12 PM
400EXJumper's Avatar
Default Won't crank
It's possible the starter is starting to go out.
Old Oct 8, 2003 | 09:36 PM
racerx5x5's Avatar
Default Won't crank
It's a 2002[img]i/expressions/face-icon-small-confused.gif[/img] Are bad starters common?
Old Oct 9, 2003 | 01:29 AM
MDE3's Avatar
Default Won't crank
I would check your positive lead wire to the starter from the battery or the connections as you suggested. Make sure it's not been rubbing somewhere and chafed through. You said you were riding in the mud when it happened.......if wet mud built up where it's chafed...could have caused a short. Mud dries out........no more short.....just a thought. While the "lights" test is not perfect, no dimming is usually a good sign of a strong battery, so look for the connection.
The other possibility is if you managed to get all your head and cylinder fins clogged with mud and were working the motor hard, it may have overheated......badly enough and it will stop the battery from turning the motor over.......
Old Oct 9, 2003 | 06:41 AM
BlackWidow's Avatar
Default Won't crank
I agree... check your connections first. Second... if it just clicks... the starter relay may be bad. I don't think that a new bike should have any problems with the battery or starter at this point.
Old Oct 11, 2003 | 12:54 PM
racerx5x5's Avatar
Default Won't crank
The starter wire was off. Thanks Guys
pgamboa
Dec 24, 2023 11:52 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
QuadRiders
Oct 22, 2015 04:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
