how much oil does a 250r hold
Old 11-03-2003 | 09:48 PM
trxs2fast4u's Avatar
Default how much oil does a 250r hold
hey i was wondering how much oil an 86 250r would hol i think its a little over a quart but im not sure i just got it its a ripper though!
Old 11-03-2003 | 10:43 PM
Bubba297's Avatar
Less than a quart in the gearcase. When I change my wife's oil, I buy the MTL fluid in a quart container. If I remember right, seems that there is usually about 8oz left over. Make sure the engine is level and remove the plug (10mm screw) from in front of where the clutch is on the sidecover. Just fill until oil starts coming out. Your done!
Old 11-04-2003 | 06:11 AM
DaBeechMan's Avatar
the oil check plug is a 10mm head, but its a 6mm bolt [img]i/expressions/face-icon-small-smile.gif[/img]
come on bubba, bolts and plugs arent screws!
haha...yaya screw you too! lol.
Your correct though, the tranny doesnt hold a quart
Old 11-04-2003 | 08:54 PM
powerslider's Avatar
700cc, measure it out and pour it in. No need to use the bolt check method this way so it doesn't get stripped out.
Old 11-04-2003 | 11:36 PM
DaBeechMan's Avatar
easy superman, no reason to strip the bolt out unless you're cranking on it with the grip of death
Old 11-05-2003 | 02:24 AM
HA2's Avatar
HA2
the drain plug is a pain. i think ill try a vaccumm tank next time to avoid removing the drain plug altogether. i cant see anyone ever stripping the check bolt.
Pehter
10-04-2024 12:00 AM
r1pilot83
Utility ATVs
15
11-26-2019 12:39 AM
wrencher82
09-28-2015 11:02 PM
Alex Rodak
09-13-2015 01:30 AM
Alex Rodak
09-12-2015 10:39 AM
