First problem with my Rancher......Help!
Old Nov 9, 2003 | 06:02 PM
hounddog's Avatar
Default First problem with my Rancher......Help!
I had my first choke cable freeze-up. It was only about -8c, and I hadn't started it for two weeks. My garage isn't heated, so it stays pretty cool in there. For this particular time, I stuck an interior car warmer close to the carb, dripped a bit of gasline antifreeze under the boot below the **** and it moved freely after 5 or so minutes. I was wondering what you folks do in this scenario? Is there anything I can do to prevent it, and where exactly in the cable does the freeze-up usually occur? Any help would be appreciated!!
Old Nov 9, 2003 | 09:26 PM
roscoe69's Avatar
common problem on rancher, wifes quad had this problem first cold snap. i believe that you did the right thing to free it up. now you should spray some lube in there while it is warm to displace any moisture that remains and then replace the boot. I haven't had any problems since i did this.
Old Nov 10, 2003 | 10:05 AM
roscoe69's Avatar
sorry houndog
reread this topic, most of the freezing problems are on the boot that is connected to the carb. try the proceedure there and it will cure the problem.
Old Nov 10, 2003 | 10:49 PM
hounddog's Avatar
Thanks for the help roscoe69, I'll give it a try!
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
