250R, 265R, 310R, Please help.
Old 01-26-2004 | 01:42 PM
Nicname's Avatar
Default 250R, 265R, 310R, Please help.
I have done the searches, and have read almost all of the posts concerning 250R Engines on this site. Now I still can't make up my mind. I have an '86 250R (short rod with a good bottom end) I would like to get a new cylinder when it is time to rebuild my top end. I would also like more power, something in the range of the new Yamaha 450's (200 yard drag). These are my choices:
Re-port my 86 cylinder
Get a 88-89 cylinder and have it ported with a cool head, 38 mm carb, and a ESR TRX 5 pipe.
Or get an ESR 310 bolt on kit, TRX 5 porting, 38mm carb, and a ESR TRX 5 pipe.
What, from real world experiences would be the best. I like the idea of a sleeper (stock 250R Cylinder), but I like the ideas of out running some faster bikes too. Any suggestions?
Old 01-26-2004 | 01:52 PM
briansgi's Avatar
Here, by mine:
ESR310 motor
Old 01-26-2004 | 01:54 PM
DaBeechMan's Avatar
what is the reserve?
310 is capable of more power generally
Old 01-26-2004 | 02:13 PM
dragracer789's Avatar
If you got the money and want a sleeper take the cylinder and get it re- sleeved wth a 295 sleeve. then get it re ported. After that you can get the bolt on products. (carb, reeds, pipe, ect). BUT a bolt on 310 kit (just a aftermarket cylinder with a 295 sleeve) has better cooling, and are capable of a little more porting, and also usually have no problems with.
Old 01-26-2004 | 02:15 PM
briansgi's Avatar
Reserve is mid teens.
Old 01-26-2004 | 02:38 PM
DaBeechMan's Avatar
thats fair.
Old 01-26-2004 | 06:42 PM
250R4LIFE's Avatar
Correct me if i'm wrong, But i don't think you can do the 310 kit with the short rod (86). You have to have the 87-89 rod. So if Nicname wants to go that big, He will have to split the cases. Personally I don't think you gain that much from the 310 over the 265. I would probably just go that way. But when you go 330, It's a whole different story.
Old 01-26-2004 | 07:04 PM
DaBeechMan's Avatar
310 pro-x barrel has bigger water jackets, and bigger transfer area. All this creates a better motor for both cooling and hp.
Old 01-29-2004 | 05:28 AM
85250ctracing's Avatar
im thinking of going to a 330 but i really want a 350. i have a ct 310 and want more speed (sand) i know esr have sick motors but im keeping this bike ct. im looking into an 88 or 89 250r quad and go esr with that one. my question, should i keep with ct racing or go esr with my trike?
Old 01-29-2004 | 12:53 PM
trx250Rob's Avatar
250R4LIFE, the ESR 310 bolts on to a short rod fine, I have one. Their 330 kit bolts on without case mods to a longrod throught the use of a spacer. You can also run a 330 and 350 on a short rod but it would requires case mods.
EIF
04-20-2017 07:15 PM
Sassinm1
09-30-2015 04:23 AM
Matt123
09-29-2015 01:29 AM
2many2ride
09-27-2015 04:35 AM
Alex Rodak
09-12-2015 09:39 AM
Quick Reply: 250R, 265R, 310R, Please help.
