Problems with 87 273X(250X)
Old Apr 13, 2004 | 02:42 PM
250x300exMAN's Avatar
Default Problems with 87 273X(250X)
If the pinging is only when you gas it then I would say it is a timming issue. You need to retard the spark. To do so you'll have to refer to the repair manuel. You can try a higher octane gas. If the timing is not too far out that should do it. If the motor has been Modified it is likely that the timing is set high by design and you'll need to run high octane all the time. Do not ride the bike if it is pinging alot, the detination can cause hot spots on the pistons and put a hole in it. This happens on cars as well.
Old Apr 13, 2004 | 11:09 PM
crappycustoms's Avatar
Thanks a lot! I will take the top end off and see what all is wrong. thank you for your time! ALL that have helped! Thanks a million
Old Apr 15, 2004 | 01:44 PM
I retimed it to, the big bore specifications. and it still does the same thing. Starting to make me mad! I am making a trip tothe local dealership 1st of May. See if they can help any. Later on Ride Hard
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
