450R cam help fast!!!
Old Apr 23, 2004 | 11:36 PM
lilthumper's Avatar
Default 450R cam help fast!!!
Ok guys, I downloaded a bad thread with directions and thought it would go smooth. The directions suck. Does anyone know how to time this motor correctly? I think I may have slipped the timing chain during disassembly. I guess I could go buy the Service manual, but I would like to ride Sunday, (this weekend). I need some real info on how to time the crank with the cam with the cam sprockets, etc.. I took everything apart and "zip tied the top sprocket to the chain as to not go off a tooth, but I think the bottom sprocket, which I can't see has slipped on the chain. Also, I think I took the chain tensionor OFF like the directions said. This is the long skinny thing with 2 8mm bolts on the left as in you are sitting on the bike and it is on your left side. Crap, I have ripped apart my turbo mustang a million times and I am lost, please help.
Old Apr 24, 2004 | 12:19 PM
rc3's Avatar
rc3
I reccomend you get a service manual, we just did my dads, and we used the service manual alot. well i hope you did not jump a tooth, good luck
Old Apr 24, 2004 | 04:57 PM
lilthumper's Avatar
Ok, no help needed. I figured it out. I stuck a long rod into the sparkplug hole and just watched it come up and hit TDC, then the Honda dealership filled me in on the mark on the top sprocket and the mark on the cam holder. I also figured out how to back off the tensioner after I took it off, you just use a very small flat-head screw driver and turn it and the rod starts to back off. The quad is running good! If anyone needs any advice on installing the HRC kit and has NO directions, give me a shout and I can help. I know this is easy after the first time, you will be like, "how in the heck didn't I know that." Oh well, just scary ripping into my first Japanese engine!
Old Jan 3, 2005 | 09:16 PM
Dfitz's Avatar
lilthumper
I know this is a old thread, but did you use the little screw driver to back out the cam tension, insted of the the tool cam chain tension holder?
Old Jan 3, 2005 | 10:15 PM
drewx's Avatar
i use a little screw driver instead of chain tension holder
Old May 5, 2005 | 01:00 PM
joeyb's Avatar
We are in the middle of trying to figure out exactly what position the cam should be in for the 450r to be in time if you can help us figure out where it should be or have any pointers they would be greatly appreciated
Old May 5, 2005 | 04:52 PM
yamahawarriormods's Avatar
i just had this problam trying to time my kfx DUAL CAMS... i dont have a manual so i went to the dealer and the parts guys let me look at theres they even made a copy of the page i needed it was sweat after that i went together smooth
Old Jul 15, 2005 | 08:56 PM
Screaming450R's Avatar
Does any one can advise that CRF 450 dirt bike cam would work on the TRX 450R quad? if so I wonder how reliable it is, I plan on getting HRC kit but I will not be using the jet kit, so it's waist of money, Please find detail info listed below of wht I plan to do. Advise will be greatly appreciate thks.
Yoshimura TRS Tri oval carbon fiber full system.
Dynojet stage II jet kit.
K & N air filter.
CRF 450 dirt bike cam shaft.
few teeth down on the rear spocket to get better top end.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Irishman301
Sep 23, 2015 01:47 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
