Rubicon /frustration
Old Aug 21, 2000 | 05:34 PM
  #31
TxDoc2's Avatar
I got that out of the shop manual. It is worth the $40 for the detail.
Old Aug 21, 2000 | 05:47 PM
  #32
TEXMud's Avatar
Thanks man, I could not remember where I got it from, but I had it handy.
Old Aug 21, 2000 | 07:29 PM
  #33
rooster's Avatar
Txdoc2, I tried the start in gear feature and it works great. I also played around to see if the front differential works as it is supposed to. I went on some small hills and got one front wheel off the ground. If I would blip the throttle, the wheel with the most traction would kick in and spin, then they both would. I think this might be where the problems on the Ranchers is coming in, you have to give it enough throttle to engage the other wheel. Then I hooked to a drag back in the garden and worked inbetween the rows of potatoes. I set the drag as deep as I could, but still couldn't get the Ruby to spin out. I would stop and then blip the throttle, and all fours would dig every time. When this drag would be set to its deepest setting, the 450ES would spin out a lot of times, or would just scratch the whole way. The Ruby didn't scratch for traction at all. Then I thought I would do the ultimate test: put it up on a jack and hold one front wheel. This was the same thing. If the throttle would be just over an idle only one front wheel would spin, and the one I was holding would just stay put. If I would rev it up a bit, it would jerk the wheel right out of my arm. A few times doing this and I was convinced that Honda's new front differential works, and works great.
Old Aug 21, 2000 | 10:38 PM
  #34
CHICKENman's Avatar
dpnfi
Seen the post on BLACK BEAR PASS you said 14,000ft that gotmy interest as I didn't think it was that high so done some diggin.I would have said 12,000 maybe but is 12,800.Have a link here you may like to see,BBP is one way so you have to have shuttle to get you back to top.You may know all this already,but you can take IMOGENGE pass into OURAY but have to truck it to the top of RED MTN PASS to start of BBP.Besure to click on pictures that you can to explode to full view.CM
http://www.4x4now.com/trcobb.htm
Old Aug 22, 2000 | 10:57 AM
  #35
SP500inNS's Avatar
Rubicon reboot procedure - Press and hold the Ctrl and Alt keys and press the Delete key twice.
This is not meant bash anyone's ATV. This attemt at humor just popped in my head as soon as I read the statement about the "Rubicon reboot procedure" from TexMud. Working with computers everyday helps too.
SP500 in NS
Old Aug 22, 2000 | 12:35 PM
  #36
TEXMud's Avatar
Yeah, I am a computer person too. When I copied that out of TxDoc2's post, I put the Rubicon Reboot phrase in my email to my house. I thought it was funny so I posted it here too. Not sure if there are any NT fans out there but what would a "blue screen of death" look like on the Rubi?
Old Aug 22, 2000 | 01:41 PM
  #37
SP500inNS's Avatar
With the screen of death a reboot, then run Norton's and then defrag!
SP500 in NS
Old Aug 22, 2000 | 02:09 PM
  #38
schtick's Avatar
An NT B.S.O.D would look something like this...
http://muskie.fishnet.com/~schtick/gauge3.jpg
Schtick...
Old Aug 22, 2000 | 02:54 PM
  #39
TEXMud's Avatar
Nice BSOD! Now send your memory dump to Microsoft so they can analyze it.
shimanok2
Jan 29, 2016 07:37 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
colt1126
Aug 18, 2015 10:38 PM
