Honda Foreman / pinion gear removal
Old 08-07-2004 | 04:43 PM
iroc11's Avatar
Default pinion gear removal
I have a 1998 Honda Foreman 4x4 and I am replacing the ring & pinion gears. How do you remove the pinion gear from the housing. I appreciate any help. Thanks!!! [img]i/expressions/face-icon-small-smile.gif[/img]
Old 08-07-2004 | 06:13 PM
iroc11's Avatar
Default Honda Foreman / pinion gear removal
[img]i/expressions/face-icon-small-wink.gif[/img]Assuming you have the housing disassembled and in your hand, look at the end and you will see a hex nut recessed inside a tube. this is a 16mm hex nut, remove the nut (a deepwell socket and a air gun works best) with the hex nut removed, now remove the pinion joint, next you remove the oil seal (34x70x11) and once removed you will see a locknut (64mm) remove the locknut and there is a bearing under that, remove the bearing (22x62x15) now the pinion will come out. When you replace the pinion usually you change the ring gear also. This all comes as a kit, although pricey you will get a ring & pinion gear as a matching set. (do not use old with new, change as a set otherwise you are looking for trouble). price runs around 330-350 dollars for the kit. Hope this helps...
hugemoth
07-20-2020 03:28 AM
neilbedwell
11-10-2018 11:02 AM
coolguy420
07-10-2015 01:17 AM
Shifts
07-03-2015 07:59 AM
lovinhonda
01-25-2000 09:17 PM
Quick Reply: Honda Foreman / pinion gear removal
