Foreman Starting
Old Dec 9, 2004 | 02:47 PM
hondabuster's Avatar
Default Foreman Starting
Originally posted by: Polaris500HO4x4
Originally posted by: hondabuster
If all you wanted to do was start it, when the battery was dead, and in gear, and no handle....strap it to another quad, and pull start it. Once it fires up, the es shifting should work.
I agree with the filter change...make sure its in correctly, it can get installed backwards, and thats not good.
that doesnt work with the es... ive tried it
Really?
Which part doesnt work? bump starting...or es working after the start?
I know on the older foremans, the battery is necessary for shifting. The newer ones, will shift, with the motor running and a dead battery.
Old Dec 9, 2004 | 06:48 PM
PINKMOON's Avatar
I have tried to jump start and pull start mine when it was not abel to shift ( I rolled it and smashed the es shifters ) The only thing that would work was to try to manually shift into neutral...It would not go to neutral at first so we tried all the other methods. After playing with it for over an hour it finally went into neutral for me..as soon as it was in neutral it started right up.
PINKMOON
Old Dec 9, 2004 | 07:06 PM
Polaris500HO4x4's Avatar
Really?
the shifters work when the battery is dead, but the foreman es wont seem to start by pull starting. the motor will revv up and sputter and sound like its running but will not seem to run... ive tried it on my buddys foreman down a huge hill just engine brakes all the way to the bottom and stops.
Old Dec 9, 2004 | 09:46 PM
markie's Avatar
Unlike my polaris 700 the foreman dose have a pull starter,and on the foreman all you have to do is change the oil and clean the air filter unlike polaris.
neilbedwell
Nov 10, 2018 11:02 AM
neilbedwell
May 31, 2015 11:11 AM
1000gade
May 27, 2015 12:37 PM
K2
Dec 14, 2000 12:45 PM
Rancheres4X4
May 5, 2000 02:09 AM
