Cold starting a 400ex
Old Dec 25, 2004 | 03:07 AM
  #21
Ozark38's Avatar
Default Cold starting a 400ex
8 degrees this morning and she fired right up.............but it did take a little more than usual. Not bad for sitting outside.
Old Dec 25, 2004 | 03:28 AM
  #22
ubertrailblazer01's Avatar
hmm... overnight at +5F...took me bout 5 to 10 minutes to start up (at friends), while my other firnds pred barely took any time
Old Dec 25, 2004 | 03:36 AM
  #23
Ozark38's Avatar
Thats unusual, my buddies brand new 04 Predator had to go back to the dealer 3 times cause it wouldn't start in 75 degree weather.
Old Dec 25, 2004 | 03:39 AM
  #24
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
don't know why it has to be 2 pumps, but if it works I don't question it.
Those carbs have an accelerator pump,,,,every pump of the throttle is a little squirt of gas
also a real easy way to flood it
Old Dec 25, 2004 | 01:12 PM
  #25
oldturtle's Avatar
If its been sitting more than a couple weeks then drain float bowl until you see steady stream of gas hitting the drain pan. Too many 400EX owners run heavy oil like 20-50 year round. Switch to 10-40 in the winter. I often turn up idle if its been sitting awhile. Start um up at least every two weeks and keep the tank topped off while sitting. If sits longer than a couple weeks use Sta-Bil. The bigger pilot is great tip. Also adjust pilot mixture screw after you get it running and it warms up good.
Old Dec 25, 2004 | 05:19 PM
  #26
dunefool's Avatar
bullhog, what elevation do you live at and what mods do you have done?
Old Dec 25, 2004 | 11:18 PM
  #27
Quad999's Avatar
This is my cold starting situation.
When it gets below 40 degrees or so it is real hard to start.
My 400EX has a 11:1 stock bore piston a stage 2 hot cam, pipe and jet kit(with a 42 pilot), K&N with outerwere, high rev box, and the air box cover removed. The only thing else modded on my engine is that I took my choke out (suppose to gain 1 hp). That was my only mistake. When I tried putting it back in I stripped out the little screws that hold the chokeplate in, and ended up breaking one of them off in the choke rod. So I just eliminated my choke all together. If I have my quad in my semi-heated garage (45 degrees) put in the stock rev box and blerp the throttle a couple times it slowly starts. The problem is I can't just order a new choke assembly, I have to order a whole new carb to get the parts that I broke.
Does anyone have a used carb I can buy?
I also her somewhere that there is a higher powed batery you can buy, but I dont know what size it is. ??
Is there anything else I can do to besides getting a new carb?
Old Dec 25, 2004 | 11:39 PM
  #28
powerslider's Avatar
Better battery; Yuasa YTX12A-BS fits stock tray....
Old Dec 26, 2004 | 12:55 AM
  #29
Ozark38's Avatar
I don't remember off the top of my head but couldn't you drill out the old screw and get replacements to mount the choke plate?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Bm400ex
Jun 22, 2015 09:16 AM
Big600twin
Jun 10, 2015 03:01 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
