300ex vs 400ex
Old 01-15-2005, 04:15 PM
300exridingboy's Avatar
Default 300ex vs 400ex
what are the top speeds of both machines... and how could you get a 300 to beat a 400
Old 01-15-2005, 07:34 PM
poopy's Avatar
55 mph for the 300 as for the 400 i am guessing around 65 since the z400 does 68. you could put a big bore kit on it but you are better off just buying a used 400ex.
Old 01-16-2005, 03:23 AM
Tyson150's Avatar
its going to take more than a bore...
Old 01-16-2005, 02:18 PM
TractorPacker's Avatar
Do you have a balloon?
Powrolls 352 kit, tweeked, will get in front of a 400ex. Bring 2 grand,though.
Old 02-13-2005, 12:59 AM
yellow400exman's Avatar
Simply just buy a 400ex.....
Old 02-13-2005, 09:04 AM
Ntrx250xJ's Avatar
I jsut spent about 2grand building a 300ex motor. And its not even a big bore yet. I cant wait to see how it does vs other quads.
Old 02-13-2005, 03:42 PM
CRRobinsonRacing's Avatar
Is 55 mph the top speed of a stock 1995 300ex??
Old 02-13-2005, 04:27 PM
Jordanw's Avatar
to make the 300ex go as fast as the 400 u could jack up the seat and put a 400ex under it..
Old 02-13-2005, 08:06 PM
NichelsonRacing87's Avatar
yeah it will take more than just a big bore kit, most people don't realize that a big bore doesn't do very much to add performance, just a little better torque and that's about it, you need a stroker crank to add TRUELY add CC's. also you need the basic bolt on's to accompany something like that, plus a rejetted carb, different cam, valves, etc. by the time you get done building a 300 you might as well buy a used 400ex, or get a 250X frame, or just use the 300, and replace either motor with a ATC350X engine, then you'll have something that will beat a 400ex without having to mod it.
Old 02-13-2005, 08:08 PM
nosliw's Avatar
my ex will do 67 and i've got stock gearing and tires
Quick Reply: 300ex vs 400ex
