86 250R clutch
Old May 20, 2005 | 11:32 PM
  #21
rdnred's Avatar
Default 86 250R clutch
Thanks once again powerslider. Maybe i will be able to race tommorow who knows. Seems like you have had luck about like me with your R too. Still i wouldn't trade it for anything though. It's always little stuff to which i guess you can expect this with this old of a machine. Thanks again.......
Old May 20, 2005 | 11:40 PM
  #22
powerslider's Avatar
Glad to help, these are great quads once you get all the bugs repaired. I tore mine completely apart and went all through it so it's better than new.
One more thing I just remembered on the drain plug is there's a non threaded section at the end of the plug I cut off to make sure it didn't contact any parts in the trans. Good luck!!!!!
If you want the update kit part number I'll get it for you, I have the box out in the shop it came in. It's called a Lifter Rod Kit.....
Old May 20, 2005 | 11:44 PM
  #23
rdnred's Avatar
Yea if you could get me that part number that would be great. Also, do you remember what year that plug for the GM was for or does it matter. And where did you purchase it from. Thanks
Old May 20, 2005 | 11:54 PM
  #24
I'll put the number up tomorrow, the plug is used in all the Chevy engines in the 70's. Try the Napa or auto parts stores, the plug has a wide sealing flange on the head and with the metal/rubber sealing washer you don't have to tighten it very tight and it won't leak.
Old May 20, 2005 | 11:55 PM
  #25
rdnred's Avatar
Thanks i'll pick one up tommorow.
Old May 21, 2005 | 12:23 PM
  #26
rdnred's Avatar
Went to the local NAPA store and got the plug this morning. Tapped the hole and cleaned it out poured some oil in it first and cleaned some of the metal shavings out that may have gotten in it. Drained it than put it new oil. Simple as that thanks for all the help Powerslider. That Hinson clutch basket and clutches sure make a difference in gettin more traction. It finally felt like i was getting all the power to the wheels that the machine was capable of puttin out with those modifications. Thanks again....
Old May 21, 2005 | 04:40 PM
  #27
Good deal, glad your up and running again. The update kit number is 06220-HB9-305.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
