Front wheel wobble
Old 11-01-2000, 05:04 PM
A400EXer's Avatar
My left front wheel wobbles pretty bad when I get it up to speed(I hit something). I have sent it to the shop, but they didn't think anything was wrong. It isn't the wheel, I have had several on to test that. What could it be, how can I fix it? Help, it is annoying! Thanks
Old 11-02-2000, 02:54 PM
power7's Avatar
Bearings or tie rod ends could be bad, mine did it and it was the tie rod ends.
Old 11-02-2000, 04:10 PM
hot_shoe_cv's Avatar
In all seriousness, I would say your shop had much to learn about diagnosing a problem. Like many dealer shops, they depend on you to diagnose a problem before bringing the machine to them & sticking their nose in it. And this at $55 per hour?
One thought, if you have added any tire sealant recently & failed to run the tire sufficiently to disperse the stuff, it may have settled in one spot causing an out-of -round tire. Also the tire may have suffered a ply separation. If you can, try the wheel & tire on another machine & test.
Old 11-02-2000, 11:49 PM
A400EXer's Avatar
I did try other tires and rims, that didn't help. Thanks for the help. Later
Old 11-03-2000, 07:20 PM
dand11's Avatar
I had the same problem with a Titan tire on my new polaris. It had a bulge on the outside of the tire and only shook at high speeds. You may have damaged the cords. Try jacking it up and place a block of wood next to the tire and give it a spin. Do the same to the front of the tire and see if the gap changes when you spin it.
Dan
Old 11-03-2000, 07:26 PM
bermbanger's Avatar
Then the actual spindle(where hub attaches) must be warped slightly.
Bratman2
08-06-2022 01:42 AM
07-21-2015 03:03 PM
KimSJoh
14
07-18-2015 07:20 PM
rcappie4
07-18-2015 07:51 AM
tporath
07-11-2015 12:31 PM
Quick Reply: Front wheel wobble
