please help i have a honda recon 250 2003 that wont start
hey i have a honda recon 250 2003 model that wont start it used to start but with a sputtering problem and it would only run on full choke. its been sitting in my garage for six months and i really want to ride please help!!!![img]i/expressions/face-icon-small-sad.gif[/img]
There is a lot of things that you can do . first open the drain valve at the bottom of the carb and drain out the gas in the float bowl. check and see if the float is stuck. smell the gas and make sure that it hasn't gone bad it real easy to tell.
make sure that the battery is up to full charge
Change the spark plug standard plug is a dpr8ea-9 NGK----winter plug dpr7ea-9----- or extended high speed plug dpr9ea-9 NGK
after doing that then it should start and run like a champ
good luck
John
good luck
John
Just take out the screws on the bottom of the carb.( NOT A NICE JOB) then the can will fall away and you will see the float. is all is ok the reinstall the can making sure that the gasket is in place and tighten the screws in place Oh yes before you do this (shut off the gas)
Sometimes with old gas in the carb the float will stick
Also make sure that the choke is not sticking check the cable at the carb.
also check to see that you have a good spark at the plug if not then change the plug cap and try again.
Let us know how you make out Please
John
John
Jun 10, 2015 12:45 AM
