some one help honda recon wont start
[img]i/expressions/face-icon-small-sad.gif[/img] ok i have a honda recon 250 2003 model i took a guys advice on how to get it going and it worked but after a half an hour of riding it started to sputter and died instantly i could keep the motor running when i give it gas but only in nutrel once i put it in gear it would struggle to stay going and die if you have any idea on how to fix it please tell
If it is like what happened to my recon after a little while of just running it like it is, you can gradually pull the choak up and it will slowly run better with the choak to the point where you can ride it. Eventualy while riding it with the choak it will again start to spit and sputter, and then you can push the choak out and it will run just as it always has, acording to my calculations this is caused from trash in the carb and cloging the jets, so when you pull the choak it lessens the amount of air getting in the motor so it will run again.
So your problem should ligh in the carb.
i have a honda and it has the same problem and it isn't the carb because i already cleaned it and tried that but i think it is something to do with the spark plug wires or some thing to do with that did you figure it out because mine does that when i go through water
Well my neighbor has an 03 recon and it did the same thing sputtered and such so I took the carb completely apart to inspect over it to make sure the slide and everything was working properly...Everything seemed fine until I got to the bowl of the carb and the jets were clogged up pretty good...so i cleaned off the jets makeing sure I can see holes through them...cleaned the needle off and sprayed cleaner in the carb making sure all of it was gone and wiped it down good...cleaned the airfilter...new sparkplug and oil just reg maintanance since it was due and man it runs like a beast now
06-10-2015 12:45 AM
