eng miss in 02 rancher
My rancher has a miss that happens about every 45 to 60 seconds. Used to only be noticable when it was cold but now it is getting worse. I will kill the engine when it does is at idle. It killed it while I was riding the other day after the engine was warmed up... any ideas what would cause this?
thanks, Bales
thanks, Bales
Could be quite a few things.
How long has it been since the air filter was cleaned and reoiled?
Has the valve clearance been checked ?
Hows the spark plug look?
Could be a dirty carb, or the gas is bad, or the mixture screw needs a tweak.
Elkaholic
Sep 6, 2015 02:44 PM
