198X ATV 200 Oil Drain Plug
Old 06-12-2006, 09:31 AM
lidger's Avatar
Default 198X ATV 200 Oil Drain Plug
Hi All,
I have an early to mid 80's honda atv 200. I recently changed the oil but the outer flange of the drain plug with the rubber gasket cracked!!!
I have been searching the web for a couple days now and cannot seem to find a place to buy a replacement plug. There are many resellers of ATV parts but I cannot find one that has the replacement drain oil plug.
Can any of you recommend a site that may have what I need?
Thank you in advance for your help!!
KD
Old 06-12-2006, 01:59 PM
KNOWSALOT's Avatar
The Facility
You can buy a new one from your Honda dealer for around $8.00
Just be sure that your o-ring is good or you will have to but it to. It doesn't come with the plug.
As for used parts,...you are likely stumbling all over the plugs and don't realize it. Honda used those SAME plugs for the valve adjustment caps on nearly everything with a single cylinder upright engine prior to the late 80's. And actually some dirtbikes still use that plug for valve adjustemnt access.
Shainasmash
05-08-2017 06:38 PM
SDR-II
09-29-2015 01:06 AM
Polaris5
08-29-2015 09:11 PM
JohnnySplat
08-06-2015 12:07 PM
momma's bike
08-06-2015 09:49 AM
Quick Reply: 198X ATV 200 Oil Drain Plug
