FRONT WHEEL BEARINGS
I have just installed new wheel bearings in a 2001 FOURTRAX 350 four wheel
Went to ride on the weekend and brake side axle was out of the front rear end about a 1/4".
Jacked the front up, grabbed ahold of the wheel and I could move top and bottom in and out. Got looking and seemed like axle bearing was getting wore enough to need a new bearing with seals.
After getting the new axles and seals into place, the wheel still moves in and out. Don't think as much but still moves.
Tried the bar under the wheel, jacked up, to check ball joints, doesn't seem to be any up and down movement of the wheel.
Any suggestions or idea's what could be causing the movement.
Thanks
Thanks
KimSJoh
14
Jul 18, 2015 07:20 PM
