300ex wont start
Old Jun 29, 2006 | 05:32 PM
zettler450r's Avatar
Default 300ex wont start
So I have a 2001 Honda 300ex that I am looking to sell however I can not get the damn thing to start... Heres what it does: If I pull it behind another quad and start it that way it will start up and run, and once it is hot you can start it back up again. However when it has been sitting for more than 10 minutes or a month whatever whatever it will not start cold.... I cleaned the carb, installed new plug, new coil, and checked the valve clearances everythign seems to be good. I just want to get rid of this quad and put the money in to my 450r's
Any help is greatly appreciated...
And you like in AZ and are interested in this Bike, I will sell it as is for 1650$
2001 Honda 300ex
400ex Front Shock Conversion Kit with 2002 400ex Front Shocks
FMF Mega Max II
UNI Air Filter
Dyno Jet Kit
Six Pack Rack
New Tires Front and Rear are about 80%
New Carrier Bearings, and just straightened the Axle
- Rims are a little bangedup from riding the desert but hold air just fineand dont wabble or anything
- Rear Plastics have normal wear no cracks
- Front Plastics Pretty Beat up, but replacements are easy to ger Front Maier Blems 90$ rears $110
This bike have been very realible and never had an issue, let the bike set for 6-8 months and wouldnt start there after, I have no use for it now since I have purchaced (2) 2005 TRX 450r's If Youre Interested E Mail Me or contact me at 480-330-2676 ask for Brian
Old Jun 29, 2006 | 09:02 PM
hondabuster's Avatar
Check your valve clearance.
Old Jun 30, 2006 | 02:14 PM
HondaMan440ex's Avatar
It almost sounds like you have a week battery. it sounds like once you get it started it will start to charge the quad enough that it will turn the motor over fast enough to start it. check the water level in the battery, or charge/replace. does the quad start when you jump it like you do when a car battery is dead?
Old Jun 30, 2006 | 04:25 PM
I will have to try and jump it using the battery from my car... I didnt think of that however I did try another battery, it may have been just as dead... I Will try that but pkeep the suggestions comming....
fullprice54
Jun 18, 2015 09:44 AM
NONEtooSMART
Jun 17, 2015 08:48 AM
Hondaislife
May 28, 2015 01:43 PM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
1000gade
May 27, 2015 12:37 PM
