carb spring
Old Jul 26, 2006 | 01:52 AM
quicksilver's Avatar
Default carb spring
hey Rinman, are you sure a dynojet kit comes with a softer spring?? I looked up one for my rancher and all it shows in the parts list is the jets and needle. no spring. Is this something they changed recently?
I will be adding an aftermarket pipe soon for some extra power, and I was thinking of using oem jets but if a dynojet kit comes with a spring i might do that instead
Old Jul 26, 2006 | 08:03 PM
mykool61679's Avatar
Default carb spring
the carb is that silver round piece under the seat with four bolts right? and when i take it off is the spring going to shoot out or what?i am going to do this for sure though.
Old Jul 26, 2006 | 08:41 PM
Rinman's Avatar
Default carb spring
I doubt it will shoot out. But if you pull it off fast then yes. Its about 10 inches long. But it is a thin spring so you should survive it if it flys. Yes its the silver thing under the seat. As far as the dyno jet kit goes, mine came with a softer spring. But that was for the Rincon. I only used the spring and needle from the kit and used Kiehin jets from jetsrus. The dynocrap jets give mixed results.
Old Jul 26, 2006 | 09:13 PM
Default carb spring
appriciate the info rinman[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 26, 2006 | 09:39 PM
  #15
Rinman's Avatar
Default carb spring
Good luck, and let us know what you think.
Old Jul 27, 2006 | 07:25 PM
  #16
Default carb spring
just took out six of the springs.and you can tell a small difference(i can get it about halfway up in first,which all it use to do is raise up an inche or two), not bad for a five minuite mod. might be able to take a little more slack out im not for sure, dont want too much out. thanks for info rinman
Old Jul 27, 2006 | 09:40 PM
  #17
Rinman's Avatar
Default carb spring
Glad you liked it. It is a nice simple mod that anyone can do. I'm surprised more people don't know about it. Everybody is always a little scared at first. I guess its the fact that your cutting something thats been engineered off your machine. But as you've just said it did make an improvement. I cut 11 coils off mine. But if your happy with 6. Leave it alone and enjoy.
Old Jul 27, 2006 | 10:20 PM
  #18
Default carb spring
i just didnt want to cut too many off.(if you can.) what exactly is the purpose of this spring? would taking a few more sections out make it even quicker( the throttle responce?)
Old Jul 27, 2006 | 10:53 PM
  #19
2manytoys's Avatar
Default carb spring
Taking too many out will cause it to bog and will also cause unwanted throttle. The ring helps the diaphram close. Thats why 10-11 coils is the magic number. Not sure how the rancher carb is. Is it just a cable slide or vacuum actuated? If it is cable actuated it will not make much difference if any at all.
ghost civic
Jan 15, 2020 07:43 AM
GregM
Mar 6, 2018 06:53 AM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
