Recon has white smoke in the crankcase
Old Aug 19, 2006 | 08:50 PM
PaulH's Avatar
Default Recon has white smoke in the crankcase
Hey everybody, a nOOb here with a question about my 2006 Recon. Today while riding I was going up and down some really steep hills one right after the other being pretty agressive. No problems. When I was done playing, I rode for about 2 minutes going slow. The engine started to sputter like it was out of gas and it died. It wouldn't restart, just turn over. So I pulled the top off the air cleaner box and, POOF, it was full of white smoke. It would then start and only idle when I gave it gas, but white smoke was still coming out of the crankcase vent filter. So I ended up disconnecting the crankcase vent hose at the engine and rode it back to my truck for about 10 minutes. When I got back to my truck it was running perfectly fine. So I connected the hose back up and called it a day. Is something wrong or is this normal? What exactly happened? Oh, I forgot to mention that I checked the oil level and it was low. Where did that oil go! Just checked the compression... 185 psi, right where it should be. No leak down after 1-2 minutes.
Update:
When I went up a hill that was really steep and had my Recon almost vertical for about 4-5 seconds. Some oil must have gotten sucked somewhere it didn't belong and this is what caused the smoke. It cleared up after a few minutes and hasn't come back. Problem solved.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
Jason Campbell
Sep 7, 2015 02:25 PM
