How do I fix a suspention squeek?
Old Sep 14, 2006 | 04:03 PM
easygo's Avatar
Default How do I fix a suspention squeek?
I have an 04 Foreman 450 that has seen very light use. The suspention developed a squeek over the past few months and I wonder where I would lube the thing. I am unable to see where it exactrly comes from, but it does make noise when the suspention is compressed and the other way around. Do I have to take things apart or there is a place for oil or grease? It is much loudert in the front. If you can give me some pointers on the problem it would of great help.
thanks
Easy
Old Sep 14, 2006 | 04:41 PM
4StrokeRider400's Avatar
i just sprayed w-d 40 up in my shockes.They have plastic in the shocks that rub together and make it squek. My 300ex does it and my dads foreman. Just try spraying a lubricant in the shock.
Old Sep 15, 2006 | 02:21 PM
hondabuster's Avatar
If the spray doesnt do it. Disassemble the lower bolt, on the front shocks. Pull out the bolt, and lube the bushing and bolt, with silicone grease, and put it back together. That should last for a year or two.
Old Sep 15, 2006 | 06:51 PM
JimmyHoffa's Avatar
Congratulations on the purchase of your honda! Take apart your entire atv's suspension and pack it with grease. "Grease guns aren't fair" -Mr. Honda
Old Sep 18, 2006 | 01:41 PM
easygo's Avatar
Thanks all for the suggestions.
thunderpower
Aug 25, 2003 07:26 PM
Eaglecollector
Apr 8, 2002 11:01 PM
Robwes85
Jul 13, 2001 07:34 AM
250rampage
Jun 24, 2001 10:24 PM
rdr
Aug 4, 2000 03:32 PM
