Honda Rancher 2002 problems
Old Sep 21, 2006 | 02:51 PM
iceman1120's Avatar
Default Honda Rancher 2002 problems
I have a Honda Rancher 2002 4x4 ES. The last two times I was riding the engine just died. After about waiting 5 minutes, I was able to start the machine again but I had to prime it using the primer button otherwise it wouldn't fire. I had a full tank of gas and didn't hit the kill switch. Once I had it running it ran great for 40 miles and then it did the same thing. This also happened on another occation and come to think of it, both times the weather was cold and rainy. Has anyone had similar problems? I'm wondering if there is a sensor or something going out? It hasn't left me stranded......yet, therefore I would like to get it fixed.
Old Sep 21, 2006 | 05:23 PM
quicksilver's Avatar
check your fuel tank vent hose. If it gets plugged, the tank wont vent and will build vacuum and not let the gas out into the carburetor. after it sits for a bit, a small amout of fuel will enter the carb and it will run again, but the same thing will happen again.
Old Sep 21, 2006 | 05:36 PM
kickass210's Avatar
sounds about right. u got something clogged. do u do normal matenience on ur quad other than the typical lube stuff?
Old Sep 22, 2006 | 02:08 PM
iceman1120's Avatar
Thanks for you insight.....I will check that out. I do run a lot of dusty trails so its a possibility.
Old Nov 7, 2006 | 05:02 PM
sandooner's Avatar
I had a simlar prob w/ a 92 250x would start & run perfect idle all day , but after running & riding for a given lenght of time just die, sometimes after 5-10 min start back up run great, die again , and feel lucky to get home. I put a new exiter coil on problem solved.
Old Jun 12, 2014 | 11:02 PM
Joni Marie Charlie Hack's Avatar
Default 2002 Honda rancher trx350 problem
I have been following your posts on this problem.. I bought a new Coil wire, didn't help.. Tried a different CDI box, Still nothing.. Put on a new Rectifire It fired up , rode less than a mile and it died, couldn't get it to start again.. anyone have any Ideas.. Thanx
toonces
Oct 16, 2019 12:11 PM
neilbedwell
Nov 10, 2018 11:02 AM
ROWALKER
Jun 15, 2015 05:38 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
aby11
May 7, 2000 07:58 PM
