38mm out of tune
Old Oct 7, 2006 | 10:23 PM
Jungle's Avatar
Default 38mm out of tune
I have a 250r I just put a 38mm PWK on and I cant get it to run right at all the carb is new from ESR it came with a 172main,52pilot,deg needle on 3rd, it sputters and spits half way thru the power band and pops and sputters big time on the top end I put a 178 main in and still does the same. I put the stock carb back on due to sand drags tommorow and it runs great im sure it will run even better if I could get the 38mm tuned Help Please!!
Mods are V-Force 3 reeds, fresh bore (stock) with Pro-lite, FMF gold,ct silencer, head shaved .010,Race gas (110) with R50 40:1
Thanks
Old Oct 9, 2006 | 02:23 AM
quicksilver's Avatar
well, if it spits and sputters up top, you need a smaller main jet, not a bigger one. try something in the high 160s and see how that works. make sure your idle mixture is right first though, then the mid-range, then the top end. the idle and midthrottle settings will affect top end a little bit. good luck
Old Oct 10, 2006 | 07:39 PM
Jungle's Avatar
ok thanks as far as idle mixture goes whats the best way to get that dialed in then what go to the pilot then main?? Thanks again
Johnny Mac
Aug 15, 2019 03:13 PM
CosmoM
Sep 21, 2015 04:57 PM
Jason Poulin
Sep 20, 2015 02:49 AM
Alex G.
Sep 16, 2015 12:13 PM
Elkaholic
Sep 6, 2015 02:44 PM
