value adjustment on 06 trx250ex
Old Oct 16, 2006 | 01:54 PM
tazman79's Avatar
Default value adjustment on 06 trx250ex
im at 25 psi
Old Oct 16, 2006 | 02:00 PM
PaulH's Avatar
Make sure the choke is off, hold the throttle wide open, crank it over 4-5 seconds.
Old Oct 19, 2006 | 12:44 PM
tazman79's Avatar
i think the timing is offf whne i put it on the mark the cylinder is down not up any idea on how to adjust it?
Old Oct 19, 2006 | 01:24 PM
PaulH's Avatar
I think the timing is fixed. Maybe it's possible to install the cam upside down or something? That's the only thing I can think of that would cause what you are seeing. Is this 250 completely stock? What exactly is the story with it?
If you remove the spark plug and the two valve cover plugs, you should be able to turn the engine over easy and watch when the rocker arms open and close the valves. The valves should be closed when the piston is at TDC and the timing marks should be lined up.
When the intake valve opens, the piston should be going down. When it comes back up, both valves should stay closed and when it is at the top of the stroke, that is top dead center (TDC) when the spark plug fires. Rotate the engine, watch the valves, put a wood dowel or something that won't score the metal down the spark plug hole so you can see the piston going up and down... just don't drop it [img]i/expressions/face-icon-small-smile.gif[/img]
These engines are pretty simple. I recommend you get a service manual because it has loads of good info and pictures and you can see how everything works...
Factory Service Manual -click here-
Old Oct 19, 2006 | 02:18 PM
  #15
tazman79's Avatar
when the piston is down the values are closed? i boght this bike as a fixer uper i dont know if any mods are done or not
Old Oct 19, 2006 | 03:32 PM
  #16
PaulH's Avatar
Rotate the timing mark another 360 degrees. The piston should be up, the valves should be closed, and the timing marks should be aligned at TDC. Here is a good animation that shows how a 4-stroke works and you can see the position of the valves. TDC is the top of the compression stroke when the spark plug fires.
4-stroke animation
A 2006 fixer upper? What the heck happened to this thing? Is it possible that somebody had the engine apart and messed with the cam? If things still aren't looking right, I would say you need to get a service manual and tear into the thing. They are not that complicated to figure out, but if something is jacked up like the cam being installed wrong, you need the manual to make sure everything is right.
Old Oct 19, 2006 | 04:10 PM
  #17
tazman79's Avatar
do you know how to get to the chain ? yeah it was in rough shpe it was full of mudd and did not start whne i bought it. only paid 1k
Old Oct 19, 2006 | 04:24 PM
  #18
PaulH's Avatar
I wouldn't even try it without a manual. Sounds like you need it [img]i/expressions/face-icon-small-happy.gif[/img]
TRX250EX service manual
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
r1pilot83
Sep 27, 2015 07:38 PM
