Rubicon vs Sportsman/sub-zero starting
I can't speak about the differences between the two. I started my Rubicon a few days ago when it was 11 below. It took a little extra cranking, but it started and ran fine. I didn't even use the primer but probably should have. As for the Hondamatic tranny. There was absolutely no hesitation at all. I'm very impressed.
I know that my rancher as an electric heater on the carb, I'm assuming that the rubicon has one also but I'm not sure about my sportsman. Should one turn the key to the on position for a little while before cranking to warm up the gas in the bowl? Or is this only operational when the machine is running.
I will say both the rancher and sp500 start similar in the cold weather, in our latest cold snap the rancher may need a second or two extra.
