Problem with Honda Rancher AT (completely lost)
Old Feb 6, 2007 | 04:04 PM
ANDY98's Avatar
Default Problem with Honda Rancher AT (completely lost)
When it is in automatic it won't come out of first gear and instead of having a "D" on the display it blinks "-- --", but I can thumb through the gears when the ESP is on. It's just the automatic and reverse that doesn't work. When I am in reverse it will go but it is very jumpy. Kind of like I am feathering the throttle. Did my computer board get wet, and can I simply dry it out. Do I need another board? Please advise. Thank You.
Old Feb 6, 2007 | 06:33 PM
LittleBill's Avatar
what year bike, some of the early rancher at's had a recall for a issue sounding very similar to your's
Old Feb 6, 2007 | 06:45 PM
ANDY98's Avatar
It's an 06. I've talked to a few people that say the computer board has gotten wet and that's the problem. I also talked to a guy in the service department where I bought the bike and he said it is probably a sensor on the enging.
Old Feb 7, 2007 | 12:58 PM
JRM's Avatar
JRM
lol, its not a computer board, these are 100% sealed computers that are next to unbreakable. My rubicon had the same error yours is showing- its in safe mode. Try pulling your negitive battery cable off for 10 minutes while leaveing your ignition turned on this will pull all power out of the system and clear any codes you may have set when rideing hard. Put it back on and see what happends, if it does the same thing your mechanic is correct and its a simple angle sensor.
Joe
Old Feb 7, 2007 | 01:06 PM
ANDY98's Avatar
Thanks for the help. I am going to try that as soon as I get off work. I'll let you know.
Old Feb 7, 2007 | 01:15 PM
HondaMechanic's Avatar
none
Old Feb 12, 2007 | 03:49 PM
ANDY98's Avatar
It is flashing five times. Do you know what that means?
Old Feb 12, 2007 | 05:08 PM
none
neilbedwell
Nov 10, 2018 11:02 AM
ROWALKER
Jun 15, 2015 05:38 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
aby11
May 7, 2000 07:58 PM
Rancheres4X4
May 5, 2000 02:09 AM
