440ex
Old Mar 21, 2007 | 11:08 PM
ianR's Avatar
Default 440ex
i have an 01 400ex and i was wondering if its a good idea 2 put a 440 kit in 4 more speed and power
Old Mar 22, 2007 | 09:10 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Default 440ex
I had an '01 400ex that I installed a 440 kit on, and I wouldn't do it again. It did give it more power and make it more torqy, but IMO if you want more power it is best to trade up to a more hi-performance machine. It will be faster and more reliable.
Old Mar 22, 2007 | 10:32 AM
yz426ex's Avatar
Default 440ex
Most times you will need to buy heavy duty head studs from the extra compression. They cost around $80 and if you dont buy them usualy the stock ones will pull and make your gaskets leak which = loss of compression. I heard you should switch to the crf cam chain too. Modding a motor will not give you any more speed. It will let you get to your top speed faster. If you want speed you mess with the sprockets. If you buy a high rev cdi you will gain 2-3 mph.
order of stuff that should be dune
pipe
filter
remove air box lid
bore kit
rev box
cam
port
carb
Old Mar 23, 2007 | 08:41 PM
crazy1291's Avatar
Default 440ex
pipe
filter
remove air box lid
bore kit
rev box
cam
port
carb
NO............. this is the order of stuff that should be done
trx450er
if you want to go even faster.....
pipe, filter, higher comp piston at 500CC big bore,
Old Mar 23, 2007 | 11:07 PM
1988fast250x's Avatar
Default 440ex
well they sell heavy duty timing chains on ebay.... also where can u get the bigger head studds??? I have been looking for some thanks
Blodg500RX
May 6, 2001 06:42 PM
mx400exer
Mar 14, 2001 05:08 PM
mhiggins36
Mar 1, 2001 02:00 PM
Robby440ex
Jan 30, 2001 05:09 PM
Robby440ex
Jan 29, 2001 11:16 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
