Hot Grips for Rancher
Finally got to plow for the first time this week. My Rancher and Moose plow worked great. The only complaint is the cold on my hands.
I prefer to wear thinner gloves for better access to the controls, but this results in colder hands.
Was thinking about getting a set of Hot Grips. I liked the model that had the wire through the handlebar. However, not sure which model(s) will fit the Rancher.
So, has anyone installed a set on theirs? How do they work? Easy install? If so, please let me know the model # as well.
Thanks in advance!
Thanks in advance!
They are simple to install....just follow directions....including using a good two part epoxy (the heat will break down lesser adhesives). Don't get too worked up about routing the wire through the handle bar....just zip tie them on the outside of the bar....with all the other cables and wires there already, you won't even notice.
