98 foreman 450s front driveshaft removal?
Old Oct 4, 2007 | 02:17 PM
79hugger's Avatar
Default 98 foreman 450s front driveshaft removal?
Hi, I have a leak at the seal where the driveshaft enters the front transfer case,do I have to remove the transfer case to remove the driveshaft? I found a diagram that shows a spring in the coupler that is at the engine but I cant get the driveshaft to move back a bit?Any ideas
Old Oct 5, 2007 | 08:11 PM
79hugger's Avatar
Helloooooo anybody out there have any suggestions
Old Oct 5, 2007 | 08:46 PM
HondaMechanic's Avatar
You have to remove the 3 mounting bolts & the front bracket for the front differential ..Slide the front diff forward to remove the front driveshaft ..
Old Oct 5, 2007 | 11:43 PM
79hugger's Avatar
Hi, a big thanks!! so the axles will have enough play to move forward with the case after I unbolt it ?
Old Oct 6, 2007 | 07:23 AM
Yes .. If your just removing the drive shaft the front axles/wheels/hubs/knuckles don't have to be touched ..
Old Oct 6, 2007 | 01:18 PM
79hugger's Avatar
Hello, Sounds great,you saved me alot of work!! Thanks again
lightninboy
May 16, 2021 09:52 PM
jettman
Jul 6, 2015 12:16 PM
yambam13
Jul 4, 2015 01:49 PM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
