shift problem
Old Oct 30, 2007 | 09:52 PM
mudgeek's Avatar
Default shift problem
I'm working on my neighbours 2000 trx350 electric shift, it runs OK but will not go in reverse. when you push the reverse button and squeeze the lever everything moves but it does not go. I have never worked on one of these so i'm kinda in the dark. any ideas would help
Old Oct 30, 2007 | 11:35 PM
quadracer95's Avatar
i have had the same problem its in the cable coming from the botton you push there is a ajustment right off of the botton on the cable just tighen it up and it will ingage
tell me if it help.
Old Oct 31, 2007 | 12:27 AM
zitaron's Avatar
Or are the revs set too high? suppose it is shifting the other gears ok?
Old Oct 31, 2007 | 01:52 AM
bal3wolf's Avatar
Sounds exactly like my problem i posted did you try the manual shifter. My manual shifter works putting mine in reverse and seemed like when id go thru water reverse would work again to. After i cleaned mine up i noticed i was missing somthing off front of my atv you might wanna look thru see if you have same issue.
Old Oct 31, 2007 | 06:25 AM
Williebee's Avatar
mudgeek there has been alot of post's on the Honda's with the ES model's , and i think you're working on first year model that honda put on the ES transmission ; there has been a recall on the first year they came out up to the 2002's something to do with the angle senor ! You should find it on the Honda forum , just do a search on Honda TRX 350 ES trouble ; the local dealer tried to sell one to my brother in 2002 or 2004 and he had already been warned by some of his co worker's about their 2000 Honda TRX 350 Rancher ES giving them trouble ! But i saw it on a thread over a year ago about a recall on the 2002's ; it's on an old thread i just don't recall the date i last saw it ! Good luck finding it ! As long as i've been on the forums i still have been unable to do a search or even get a picture to post , so good luck ! .......
Old Oct 31, 2007 | 08:22 AM
mudgeek's Avatar
thanks to all must have been too long a day yesterday. once my brain started to work again last night went back on and did a search of the forums and found lots of helpful post. Thanks to all that replied[img]i/expressions/face-icon-small-smile.gif[/img]
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
