2006 TRX450ER STARTING ISSUES
Old Nov 27, 2007 | 12:30 PM
sevibro's Avatar
Default 2006 TRX450ER STARTING ISSUES
POSSIBLY NEEDS VALVE ADJUSTMENT, CRANKING OVER BUT WON'T ACTUALLY START UNLESS BUMPED. RUN'S OK AFTER THAT. SEEMS LIKE IT HAPPENED OVER NIGHT. I'M GOING TO ATTEMPT TO ADJUST THE VALVES MYSELF. I HAVE THE SERVICE MANUEL AND THE FEELER GAUGES. IS IT THAT HARD, AND DO YOU THINK THAT THIS IS THE PROBLEM? NEW PLUGS,AIRFILTER,FRESHGAS,NEW OIL AND TRANS FLUID. AND SPARK BUT NO START !!!
Old Nov 27, 2007 | 01:01 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
If it just started happening, I would suggest perhaps a clogged idle (pilot) jet, caused by a bad batch of gas maybe????
Do you have stock jetting??? These are jetted lean from the factory, and it wouldn't hurt to fattin it up a little anyway...which will help it start more easily.
Old Nov 27, 2007 | 01:12 PM
sevibro's Avatar
can i just clean my jets myself, is it that hard. Yes this is stock jetting
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
BEEFKING69
Jun 17, 2015 12:38 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
