how do i put a jet kit on my 300ex??
Old Jan 5, 2008 | 01:11 AM
richard212's Avatar
Default how do i put a jet kit on my 300ex??
how do i put a stage 2 jet kit on my 1999 honda 300ex?? o yea and how do i tighten up my chain? it keeps poping off!!!
Old Jan 5, 2008 | 04:38 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Start by buying a service manual!
Loose the 4 screws on the back of the swingarm. To the left side will be a ring that you rotate forward to make the chain looser and back to make it tighter (the bearing carrier is excentric and turning it changes the length of the rear sprocket from the front sprocket). Make sure you have the proper amount of chain slack (somethng like 1-1.5" I think). Retighten the screws.
What have you changed that makes a rejet necessary????
Do you already understand carburator basics??? Things like the relationship between the slow jet, needle, and main jet??? If not, study up on that first. http://www.dansmc.com/MC_repaircourse.htm
I know these jet kits come with ballpark recommendations, but ballpark is all they are! You have to install different jets and ride it and do plug checks to see how it works. Do be aware that if you get it lean, you can damage your engine!
Jetting is more art than science! If the object is to learn jetting, then go for it. If the object is to get out and ride and not spend a bunch of time diddling around, then have it done by an experienced professional.
Old Jan 5, 2008 | 11:36 AM
richard212's Avatar
i have a k&n filter and outer wears outerfilter and it is bored 30 over and i have full dg exhaust
Old Jan 5, 2008 | 12:16 PM
juttin_15's Avatar
Definetly jet it if you have a dg exhaust, i cracked my trailboss piston because i didnt jet it
Old Jan 5, 2008 | 03:15 PM
Red Rider
Don't ride it until you get a rejet...it will be way lean!
Old Jan 5, 2008 | 04:08 PM
hondabuster's Avatar
To change the main jet, use a 6mm socket. The pilot jet is a flat blade screwdriver.
One of the best ways to jet, is to learn the symptoms of lean and rich, and rejet to correct those issues. Reading spark plugs can be a huge waste of time, unless you know exactly where on the porcilene to look. See my gallery for views of where to look for jetting on the plug. But between doing the plug chop correctly,and todays gaoline...its not easy to do a good reading.
Heres one of the better articles out there on jetting, and it explains the symptoms of lean and rich.
http://www.motorcyclecruiser.c...carburetion/index.html
Old Jan 7, 2008 | 08:14 PM
richard212's Avatar
do i have to take off the carberator to put it on??
Old Jan 7, 2008 | 08:46 PM
mikem92's Avatar
the jets are inside of the carb. you have to take it apart.
you sound like my buddy greg
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
