stuck in low speed
Old Jan 7, 2008 | 02:07 PM
kgross77's Avatar
Default stuck in low speed
I have an 06 rubicon that seems to be stuck in low gear. It has D1 D2 ESP and these keep flashing and when i put it in reverse it miss fires like crazy. I was running it pretty hard through the deep snow. Any suggestions would be helpful before I take it back to the dealer and get charged through the nose to fix it.
Old Jan 7, 2008 | 03:24 PM
JeffinTD's Avatar
It is in limp mode, where the computer detects a problem...
This thread describes the procedure to get the computer to flash out a diagnostic trouble code. Try that, and post back what you get.
Rubicon Code Reading
(Man, maybe there needs to be a sticky on reading Rubicon codes, and what the codes are).
Old Jan 10, 2008 | 12:56 PM
pyro 400ex's Avatar
how hard were u running it. sounds like u gout stuck pretty bad. should of gotten a bigger honda.............hahahahahahaha
Old Jan 10, 2008 | 06:26 PM
kgross77's Avatar
sorry it took so long to get back. It flashes 11 times and then just keeps repeating those 11 flashes. I tried to clear the codes like gimpster suggested but nothing has changed. What does 11 flashes mean?
Old Jan 10, 2008 | 06:29 PM
kgross77's Avatar
Hey pyro??? Your Grounded. HAHAHAHA. I'll plow you up in a big pile. If I can get this thing fixed
Old Jan 10, 2008 | 06:58 PM
JeffinTD's Avatar
11 is ECM motor driver circuit. Book says likely cause is ECM, but later it gives some things to try first.
It says to check the 5p connector on the ECM and the 2p connector on the motor.
It then says to pull the 5P ecm connector and check voltage between red/yellow wire and ground. If less than 11, bad wire between ecm and battery.
Then check for continuity between the green terminal and ground. If none, bad ground wire.
Then disconnect both the 5P and motor 2P connectors and check for continuity between the two connectors. If one is open, bad wire somewhere.
It then says to check for continuity between the 2 pins on the motor side to see if it's abnormal, but it doesn't say what normal is. Usually a person would expect a few ohms on an electric motor. You could probably pull it and apply voltage across the pins to make sure it spins.
Then it says to connect everything back up and turn it on. No error code= temporary problem that went away. Still getting 11 means bad ECM. Replace and do the initilization thing.
Anyway, that's what the book says. Maybe Gimpster will give us some other ideas.
Old Jan 10, 2008 | 07:10 PM
kgross77's Avatar
thanks for getting back to me. I will try these checks this weekend and will let you know how I make out.
Old Jan 10, 2008 | 10:40 PM
pyro 400ex's Avatar
ya what ever old man you cant even catch me im so much more faster than u are. but what ever i will see u tomorrow.......
Pehter
Oct 3, 2024 11:00 PM
Jeff Roper
Feb 1, 2022 11:48 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
Jackg17
Sep 26, 2015 09:30 PM
