draining fuel on400ex
Old Jan 14, 2008 | 12:20 PM
bxbsb11's Avatar
Default draining fuel on400ex
how do i drain the fuel on a 2005 400ex
Old Jan 14, 2008 | 12:39 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Pull the fuel line that goes down the the carb. off, and let it drain.
Old Jan 14, 2008 | 02:08 PM
hondabuster's Avatar
An easier way....put the overflow tube from the carb, into the gas can and open the drain, at the bottom of the float bowl. This will also flush all the crap out from the float bowl.
Old Jan 14, 2008 | 02:29 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Better yet....I would pull the tank off the quad, turn it upside down and dump it out....that way you will get any crud out of the tank along with it! Then rinse the tank with a little gas a couple times while you are at it. I save the waste gas for cleaning parts.
It's easy! Remove the plastic around the tank. The tank has just a couple bolts up front and some straps in back holding it down. Close the fuel valve and remove the fuel tube. Pull the tank off.....
Old Jan 14, 2008 | 02:46 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Take off the gas cap and flip the quad over. Shake it around real good.
Na, just kidding. Take the guys advice above. Either of those sounds good.
Shainasmash
May 8, 2017 06:38 PM
kester_holmes
Sep 10, 2015 08:27 AM
JohnnySplat
Aug 6, 2015 12:07 PM
momma's bike
Aug 6, 2015 09:49 AM
Shifts
Jul 3, 2015 07:59 AM
