03 Rancher recoil starter
Old Feb 10, 2008 | 10:52 PM
bigjake34452's Avatar
Default 03 Rancher recoil starter
my 03 rancher has a back up recoil starter, i pulled it once and it wont go back in, (i think i pulled it out too far, i guess i dont know my own strength [img]i/expressions/face-icon-small-tongue.gif[/img] ) any way, i was wondering if there was a way to fix this? i posted about a kick start conversion but i honestly doubt there is one, is there a way to just take it off and block it off? honestly that recoil starter is crap and is actually easier just to push start it. any advice would he helpful, thanks.
JAKE [img]i/expressions/beer.gif[/img]
Old Feb 11, 2008 | 10:48 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The recoil starter is prone to collecting dirt in it, if you are in the wet and mud a lot. The dirt will eventually wear on the seals and it will leak oil. There are blockoff plates available out there.....
Old Feb 11, 2008 | 11:39 AM
silverado046.0's Avatar
Instead of blocking it off, you can take some hi temp rtv silicone and place at the bottom of the weep hole, on the top of the handle where the knot is tied in the rope, around the spot where the handle sits inside the "cup" of the plate, and take the plate off and place silicone all around it. This should keep all moisture and dirt out. A lot of people I know have done this.
Old Feb 11, 2008 | 03:52 PM
thanks for the advice, i think im just going to do the silicone thing, hopefully it works well.
Old Feb 11, 2008 | 07:15 PM
LittleBill's Avatar
ps, you can't push start a rancher, without moding some electrical on the foot shift and you can't do it on th es. ps the block off plate sucks if you need to do valve clearances. bump start is pretty damn hard to line up, my buddy put his pull start back on after that.
we simply silicon the hell out of the pull starts
Old Feb 11, 2008 | 08:22 PM
i have push started this bike before, but i am just going to go with siliconing the starter.
Old Feb 11, 2008 | 09:46 PM
Just make sure that when you buy the silicone you get the high temp stuff. Trust me. If you don't it will melt off due to heat off the engine and then you'll have to do it again!
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
Clint Russell
Sep 25, 2015 03:20 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
