battery help/oil temp
Old 02-13-2008 | 07:53 PM
dan_marois's Avatar
Default battery help/oil temp
Hi Im just wondering if anyone knows about charging the battery on my 2000 foreman 450. when I went to charge it there are to red covers rather than a black and red . also should I be charging it or will it self charge if I pull start the machine and let it run. Lastly when I pull start the maching the display flickers in and out and the high oil temp light remains on is this just due to the display being innoperational because of the battery?
thanks again
Old 02-13-2008 | 09:04 PM
Gimpster's Avatar
If the battery is that dead, the charging system will not recover it to a full charge state.
The meter is acting that way because of the battery condition. I would check if the cables are tight, then charge the battery with a charger
----- Gimpster -----
Old 02-13-2008 | 09:30 PM
dan_marois's Avatar
just wondering how to connect the charger both the covers are a red positive colour
Old 02-13-2008 | 09:34 PM
Wayne36's Avatar
Is there a "+" and a "-" beside either cover?
Old 02-14-2008 | 12:13 AM
Higgy's Avatar
Your negative (-) terminal should have a wire running from it directly to the frame. And the positive (+) terminal should have a wire running to some electrical components.
Hunter100us
10-07-2015 11:46 PM
scram5050
09-03-2015 05:06 PM
scram5050
08-19-2015 02:19 AM
cody500ho
14
08-14-2015 05:03 PM
ltrmc02
07-22-2015 04:50 AM
Quick Reply: battery help/oil temp
