2005 honda rincon 650
Old Mar 14, 2008 | 08:26 PM
BIG PIMP's Avatar
Default 2005 honda rincon 650
My honda is making a knocking noise, but once it warms up it seems to quit. Any ideas?
Old Mar 14, 2008 | 08:28 PM
LittleBill's Avatar
it burning oil? could be the piston banging around in the cylinder till it gets up in temp. seen it on trucks not much at all on honda's.
check the compression
Old Mar 14, 2008 | 09:12 PM
Gimpster's Avatar
Replace the cam chain tentioner. It has gone bad
If you want to test it, remove the tentioner, push in on the tentioner guide with a screwdriver and start the quad. constantly hold tention on it because if you let it slack, the cam can jump time. the noise should be gone. Turn off the quad before too much oil splatters everywhere.
Then replace the cam chain tentioner because you found it is bad
They knock so bad you swear a piston or rod has went south. Not the case though
----- Gimpster -----
Nondem
Feb 22, 2020 12:20 PM
txpedsrt1
Feb 3, 2017 08:07 PM
sportsman2005
Technical and How-To Articles
Aug 19, 2015 10:52 AM
colt1126
Aug 18, 2015 10:38 PM
tporath
Jul 11, 2015 12:31 PM
