still hope for us 300ex owners
Old Sep 1, 1999 | 03:56 AM
slade's Avatar
hey AL300ex somebody said me that whit a bore lower than 355cc will not affect the reliability on a stock motor.. do you know if tinity can bore the side i whant.. 355cc
THAT sound like good whit a fmf pipe, air filter,high compresion piston (wiseco), new racing cam , carb 34 =) do you think the
i will put the oil cooler of the 350x on for keep the temperature low, holley shot tire
do you know on what consist a jet kite k&n
the stock crank will resist?!? (answer that
please)
more later i will put gaz chocks and rear wheel space
and a A-arm from 250r..
WOAHhhhhhhH i think that will be the perfect quad
and a more top end sproket set
any other important mods?!?
well i know what i whant but where can i find good bore up job.. and where find the other mods. im from quebec (canada)
slade 300ex 1998
Old Sep 1, 1999 | 09:21 PM
AL300EX's Avatar
Any machine shop should be able to bore, the crankshaft will be fine with the upgrade,and the jet kit consists of air filter and some jets 128 -140 - i use the dyno jet kit.I have no idea that the 350x had a oil cooler but you can get a Jagg oil cooler for the 300ex from White Bros.
Old Sep 2, 1999 | 12:49 AM
slade's Avatar
thanx dude.. i like your help
and for the stroke at the top to make the cam fitt to the piston who can do that job right?
is the timing will be right after all the mods?
and reliability ?
is it true that a racing cam on a stock 350x give 10 more HP ?
if a 350x is 27hp.. do you think the 355cc will aproxitively be the same or 30hp and that whit no other mods..
cam = 10hp more..... 27 + 10 = 37 hp
whit pipe, air filter whit jet kite
wiseco 1:12 , carb 34mm
humm if that dont make 42hp.. its strange
or the 10hp cam guys is a lyer
i think all that will give like 35hp
what do you think about that ?
how many hp will be a 355ex like that
whit a top end crank,sproket,cam and all that mods how many MPH do i get
i hope can follow a banshee before.. he put the 6th gear
Slade 98 300ex
mywifesquad
8
Sep 21, 2015 08:20 AM
Wiley wolf
Sep 7, 2015 08:32 PM
Brandon400
Sep 5, 2015 08:44 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
cdstang
Aug 31, 2015 07:52 AM
