antifreeze
Old May 11, 2008 | 01:30 PM
jrafter's Avatar
Default antifreeze
do you use the honda stuff or do you use other brands
i used walmarts 50/50 brand today
Old May 11, 2008 | 05:25 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default antifreeze
Check the coolant section of your owner's manual (pg 110).
Needs to be ethylene glycol based with corrosion inhibitors specifically for an aluminum engine. If it needs diluting, use distilled water not tap water. Silicate inhibitors may cause premature pump wear or blockage of radiator passages, etc., etc.....so be darn sure you didn't use the wrong stuff!
I always add Redline Water Wetter.
Old May 11, 2008 | 05:45 PM
jrafter's Avatar
Default antifreeze
it is glycol based and it 50/50 so i didnt have to add water.........i check with the honda dealer and they said it wasnt a problem
its silicate free
phosphate free
it was just cheaper at $7 dollars a gallon compared to $18 for 64ozs
i will spend top dollar on my 4wheelers it just didnt seem worth it
Old May 11, 2008 | 08:21 PM
Malachi's Avatar
Default antifreeze
If it's the orange antifreeze you should be alright. The green stuff is not made for aluminum engines. And mixing the orange and green or possibly the ATV stuff with green can be very bad. The 2 do not mix and will coagulate. Which will then make a big mess inside your cooling system.
I tried mixing in an old Mazda Rx7 years ago and found out the hard way. Had to get the radiator and heater core power flushed, replace waterpump, thermostat and all new hoses. What a nightmare!
Old May 11, 2008 | 09:36 PM
jrafter's Avatar
Default antifreeze
its all green.......... i didnt mix anything flushed it out and added all new
Old Jul 10, 2008 | 12:35 PM
TIC's Avatar
TIC
Default antifreeze
How can the Green stuff not be correct? Hell my rubicon came from the factory with GREEN in it!
I have since swithced to PEAK GLOBAL. it required a flush. No big deal. Yes I got it at wally world for about half the price of Hondas magic antifreeeze.
Old Jul 10, 2008 | 12:47 PM
TLC's Avatar
TLC
Default antifreeze
Any Anti freeze that is made for Aluminum (I think thats all they sell now) and my stuff was green from day one also.
Old Jul 10, 2008 | 06:56 PM
wlvrn's Avatar
Default antifreeze
honda for mine [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 11, 2008 | 07:57 PM
Capita's Avatar
Default antifreeze
My 420 rancher came from the shop with green? Are you sure about only using orange? First I heard of that
Old Jul 11, 2008 | 10:24 PM
tramp's Avatar
Default antifreeze
Green/ Orange, what the hell!
The orange antifreeze was developed back in the mid 90's by Texaco as an extended life antifreeze for GM. At that time, NO, you could not mix the green and the orange, it was not directly for aluminum., only a change in color to signafy " the extented Life", GM claimed 100,000 miles before changing. Another one of GM's wild and wacky sales gimicks. Today most all antifreeze is designed for aluminum engine parts and most of todays antifreeze, wether green or orange can be mixed. Buy what is cheap and use it.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
JohnnySplat
Aug 6, 2015 12:07 PM
Bom2000
May 13, 2003 10:42 AM
Psycho
Mar 30, 2003 08:11 PM
