to baffle or not to baffle
Old 06-24-2008, 05:27 PM
kmaukamp's Avatar
Default to baffle or not to baffle
i took the baffle out of my trx450r but a friend told me that it could damage the valves that way. so know i'm wondering if i should put it back in.
Old 06-24-2008, 06:39 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
if you popped the baffle out you might need to rejet, wont hurt the valves. but you will burn the motor up.
Old 06-25-2008, 10:19 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
<div class="FTQUOTE"><begin quote>Originally posted by: DS650powe
if you popped the baffle out you might need to rejet, wont hurt the valves. but you will burn the motor up.</end quote></div>
To clarify, you will burn the motor up IF you need to rejet and do not. When pulling the spark arrestor out, you allow more air flow and need more gas flow to compensate. If it starts backfiring stop riding it immediately until you can rejet. Other than that it will not hurt anything.
Old 06-25-2008, 10:33 AM
kmaukamp's Avatar
IT DOESN'T REALLY BACK FIRE EXCEPT FOR WHEN I GO TO START IT. IT WILL SOMETIMES GIVE A QUICK POP. BUT VERY RARELY.
Jason Poulin
09-20-2015 02:49 AM
Bigtwin700
09-09-2015 09:32 AM
Huntingdeer
08-23-2015 12:06 AM
raceware
07-30-2015 06:59 AM
cSchwartz
07-12-2015 07:42 PM
Quick Reply: to baffle or not to baffle
