is higher octane gas better at high altitude?????
Old Jul 10, 2008 | 09:08 PM
tweekin74's Avatar
Default is higher octane gas better at high altitude?????
i asked about the high altitude trx 250 honda about if it would run in colorado with just removing the air filter cover and got some great answers but would a higher octane gas in colorado comming from texas maybe help out in high altitude anyone with a clue i would sure apriciate your help and thx again for the other topic...
Old Jul 10, 2008 | 11:23 PM
Doctorturbo's Avatar
GOT BOOST!
It will actually hurt.
O2 speeds up the burn rate. The higher up you go the less O2 you have.
In other words, if you were right on the edge of detonation lets say in Colorado and go to lets say the LA dunes, your engine will detonate because your engine will get a bigger gulp of air on each piston stroke.
Old Jul 11, 2008 | 10:52 AM
tramp's Avatar
Higher octane at higher altitude will help with pre-det or knocking and can prevent burn down especially on two stroke machines if jetted a little lean. I always run higher octane fuels in my snowmobiles because of changing elevations and the lean jetting I run. When riding in the mountains, I jet for the highest elevation I will be running, but you never start out at the elevation.
Ex: I ride at over 11,000 ft., but start at 7000 ft. So buy using a higher octane fuel, you prevent any pre-det at the lower starting elevation. However 4-strokes are a little more forgiving.
Just remember: Higher octane fuels DO NOT produce horse-power, only prevent and prtect against pre-det.
Old Jul 11, 2008 | 10:56 AM
DODGE57HEMI's Avatar
Mopar Man!
I live in Co. and use higher octane gas but not for the reason you would think, it is because regular unleaded gas is only 85 oct!
Old Jul 11, 2008 | 11:20 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
While you are in Colorado, notice that pump gas has a lower octane than down at low altitude. Decide what that is telling you......
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Johnny Mac
Aug 15, 2019 03:13 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
