2002 ES Rancher wont shift
Old Aug 16, 2008 | 12:31 PM
01mxz's Avatar
Default 2002 ES Rancher wont shift
HI everyone,
I have a 2002 rancher ES with around 9500 miles. Never have had any problems until yesterday with the ES. I can still shift manually but it wont shift using the ES. It runs fine still and starts good so I sure its not the battery. The problem started yesterday I started the machine took off using the ES as normal was fine shifted through the gears to 4th heading to my barn. I got close and went to downshift to 3rd still using the ES and it wouldnt shift down I continued to the barn where i stopped. I tired to shift up and down with the ES and got NOTHING. I shut it off and started still nothing. I used the manual lever to shift it to Neutral to get it to start and drove it home using the manual lever.
I have no clue what the problem could be as it is an 02 it doesnt show any codes. I am a good mechanic but the electric area isnt my strongest point.
Wondering if this might be a common problem like and angle sensor going bad?
I think it could be a broken wire, but really have no clue not even sure where to start.
Any help will be much appreicated
Thanks BOB
Old Aug 17, 2008 | 10:19 PM
waterboy2k's Avatar
hey 01mxz i have a 2000 rancher with the same isues, try checking the fuses behind the battery compartment. especially the 30 amp on the right hand side this is for the shifter motor.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
Elkaholic
Sep 6, 2015 02:44 PM
