Honda automatic tranny
Old 09-03-2008, 07:04 PM
Cummins123's Avatar
Default Honda automatic tranny
Im trying to find info on Honda auto trans. Can anyone explain the difference between the trans. in the Rubicon verse the Rincon. Also the Rancher AT.
Old 09-03-2008, 07:30 PM
TLC's Avatar
TLC
TLC is offline
The Rubicon has a "D" option for a low range while the Rincon does not. Believe it or not a 500 Rubicon could probably out pull a 680 Rincon in a dead weight pull.
Old 09-03-2008, 08:13 PM
Cummins123's Avatar
I was told the Rubicon has a hydrostatic trans and the Rincon has a trans simular to a honda civic.
Old 09-03-2008, 09:02 PM
HondaMechanic's Avatar
The Rincon uses a 3 speed gear type transmission each gear has it's own clutch pack , it also uses a torque convertor ... The Rubicon uses a hydrostatic pump which has an adjustable swash plate that uses 5 preset angles that simulate gears ..
Old 09-03-2008, 09:08 PM
Cummins123's Avatar
What type of trans. does the RancherAT have?
Old 09-03-2008, 09:16 PM
abitibiquebec's Avatar
same of the rubicon but with no low range so its suck.
Old 09-03-2008, 10:10 PM
Cummins123's Avatar
I have a 07 Rancher AT and for some reason top speed is 36mph, would the trans play a factor?
Old 09-04-2008, 12:12 AM
Gimpster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: abitibiquebec
same of the rubicon but with no low range so its suck.</end quote></div>
Now there is a very thought out intelligent statement !!
Blew my hat off...wow
----- Gimpster -----
Old 09-04-2008, 12:14 AM
Gimpster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Cummins123
I have a 07 Rancher AT and for some reason top speed is 36mph, would the trans play a factor?</end quote></div>
Most likely the centrifugal clutch shoes and drum are burnt, slipping
Old 09-04-2008, 01:06 PM
hevbound's Avatar
What size of tires do you have on your Rancher AT. My 07 rancher AT tops out at 53 mph. Everything is stock.
Quick Reply: Honda automatic tranny
