honda 300ex
#51
<div class="FTQUOTE"><begin quote>Originally posted by: lilc9928
found one, would this work?
<a target=_blank class=ftalternatingbarlinklarge href="http://cgi.ebay.com/ebaymotors/Honda-300ex-complete-wiring-harness_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66 Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c2 93Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZ item280291446341QQitemZ280291446341QQptZMotorsQ5fA TVQ5fPartsQ5fAccessories
">http://cgi.ebay.com/ebaymotors...sQ5fAccessories
</a>
oh and would you know whats wrong with the clutch??? i pull the clutch and it doesnt do anything... the cables hooked up to...</end quote></div>
yep it should work( some years have a diffrent stator plug ,but juist hard wire it)
the harness has the rectifer and some other electiral parts as well ..
look on the engine case where the other end of the clutch cable connects ...pull the clutch and look for movment...
</a>
#53
it does move. i dont know whats wrong with it</end quote></div>
i guess the clutch is sticking ...probally from sitting up..I think if you get it running it will freeup ....shift real easy till you get the clutch working so you dont kill the trans.. my 300ex sat up for a while and the clutch was grabby when pulled in ..but it cleard up quickly
#55
yes real easy ,you can no cluth shift with out hurting it if you learn the shift points or juist go real easy ...and it will most likley free up ..if not youll juist have to go in and investagate..
( if your real concerned about the clutch go in now ,and seperate all the clutch pads and plates clean them and put them back in,you will need a couple of specialty tools from honda....)..
I bought my 300ex last year and it had sat up in someones garage..i fired it up,and shifted to first with the clutch pulled in ,it went foward so I rode it around a while playing with the clutch ...and the problem got better the first day ...and by the second weekend had cleared up all toghether
#59
well...got my complete wiring harness for 61.00 shipping included, not bad. And then i bought some axle bearings.
These should come in next week so after i put the wiring harness in hopefully it'll start then, if not i dont know what it is then.
#60
i got a 300ex iv had for 4 years...... i got a guy that iv found that works
as a parts guy at a dealer.... he is a 300 genuis..... he raced one for like 3
years.... i asked him if there where any mechical changes from the old ones till the newest ones he says the only changes are just looks...... all the mechical parts should be exacly the same.....
