another rancher ?
Old Apr 5, 2009 | 04:05 PM
tony cub's Avatar
Default another rancher ?
My 05 rancher At is blinking the esp 6 times.I did a search and saw that it is the angle sensor (this sensor has been replaced by the dealer many times before under warranty)now i have no warranty and have to do for myself.i noticed it as a recoil/spring to it.does it have to wound up to be installed or just slip it back on?BTW new here and it looks like i'm not going any where since i own a rancher.lol.thanks
Old Apr 5, 2009 | 11:17 PM
lifeisgr8's Avatar
my 05 rancher is blinking 5x and won't shift out of 1st and reverse feels like i am flooding the motor? does this sound similar? if so where is the angle sensor?
thanx
Old Apr 5, 2009 | 11:47 PM
tony cub's Avatar
same deal,mine in reverse sounds like it has a rev limitter.mine is the at model and the angle sensor is on the left side of the motor.you will need to remove the cover and its a black round plastis thing that has wires connected to it.does your grind when to put it drive?
Old Apr 6, 2009 | 04:39 AM
HondaMechanic's Avatar
The angle sensor on the TRX400FGA/FA must be pre-loaded as it's being installed ..
Old Apr 6, 2009 | 07:08 AM
papahouse's Avatar
WHen you're ready to sell them let me know.
Old Apr 6, 2009 | 08:34 AM
tony cub's Avatar
one more ?.when you remove the gear selector motor,do you have to set it up a certain way?or do you just slide it in?how do you reset the ecu?
thanks guys for all the info.i will be buying the sensor and a service man. in the next few weeks.its pretty hard to spend all that money with these times.if anyone has a used manuel at a good price,let me know.thanks
Old May 22, 2020 | 09:03 AM
Tiger-64's Avatar
thanx
Have the same problem but its flashing 12 times, did you find out what the problem was , Thanks
Old May 23, 2020 | 02:35 AM
Fault code 12 on the 400 auto is ECM motor driver circuit, not sure what that means but I would go for checking the motor's brushes are OK, and inspect the wires that go to it for obvious breaks.
Old May 29, 2020 | 01:45 PM
barongan's Avatar
Following!this seems like a very interesting thread
Frogger1
Nov 13, 2010 10:16 AM
demo08
Jun 25, 2008 10:45 PM
mobe0213
Jan 17, 2008 04:20 AM
Atvstevo1337
Feb 8, 2006 03:37 PM
BCNUCS
Aug 7, 2005 05:59 PM
