06 Rancher 400AT vs 06 500 Rubicon
well when I get my Rancher gets sold it's probably gonna come down to whatever I can get the best bang for my buck. I do use my 4 wheeler a good bit at my hunting land for odds and ends but nothing that I could really classify as actually work to sway me more to the foreman. So I'm just gonna keep my eyes and ears open. Thanks for all the advice. I greatly appreciate it
The Rubicon is liquid cooled 4 valve engine, solid rear axle, with a continually variable hydrostatic drive, with a low and high range. It moves a swash plate to effectively change ratios. It can also emulate a 5 speed by allowing you to put it in a mode that allows the rider to "shift" between 5 preset ratios with up and down buttons.
Chassis/suspension and seat of the pants power is pretty similar between the two.
The Foreman is stone-axe simple. The Rubicon is a bit faster between forward and reverse, and it can also change gear ratios with no dip in power delivery, which can be an advantage when plowing.
The Rubicon also holds a ton of oil (like 5+ quarts) due to the hydrostatic transmission.
Hello, I have a 07 Rancher ES, I also was concerned about the problem with the electric shifts, I have abused of the changes with no problems so far, I just would like them to be faster. I get impressed with the big ATVs, and the foreman looks fantastic and big enough for me, but I am a trial guy, so I'll keep my agile 420, and some times bigger does not mean better. YouTube - DAVID vs. GOLIATH (420 Rancher takes on 800 Can-am)
I am not sure about change it for a foot shifts Rancher, I guess I am just comfortable with ES and a bit afraid of foot changes, though I think it is just a matter of getting used to it. However, regardless of the option you choose, you will have a very good ATV.
#16
lol. Love my new foreman but had to take it into the shop after I got it because it was throwing code 13 (throttle position sensor) and thought it might have been the recall I heard about but my local shop said my Foreman wasn't in the recall and that it needs a new throttle position sensor. he said the sensor itself was $91. Didn't really think my fourwheeler being carburated and manual shift would really have many sensors but evidently it still does. I just don't see how this Foreman messed up a sensor. It's never even seen dirt i don't think. Oh well, hopefully the sensor won't go out again.
What exactly does the throttle position sensor control? I mean the ATV runs great and didn't even notice the error code til my buddy saw it. As far as throttle position I just thought it had a cable running to the carb
#17
It provides in-put to the computer for timing contol.
The computer needs these inputs to calculate engine load. The computer needs to know the angle of the throttle plate, gear, rpm and speed so it can adjust the timing for the given condition.
Nice looking Foreman.
